Summary: Global Project Constants
Revit should allow for the inclusion of Project Constants to be included in the Project Information. This would be similar to adding in Project Parameters. These constants would be available to all Revit objects the user selects in the Categories. They should allow the use of shared parameters so these can also be included in tags and schedules.
Description: Global Project Constants
How Used: One example of where this could be use is in egress units. Once entered it would be available to change the value used for calculating egress units for all the doors in the project without having to set a value for each and every door type.
This would also allow values to be used on several objects at once. You could input a value that would then be used by both a room area and an area area for instance.
Feature Affinity: Settings - Project parameters
Submitted By: Aaron Rumple on August 29, 2008
