Hi all, here's a dilemma for all you hardcore AMEPers out there (I think):
I've developed a set of custom air terminals with custom properties that, when combined with some nifty property set definition (PSD) code, allows me to tag all different types of air terminals using just one tag (supply diffusers, return grilles, sidewall grilles, etc.).
Typically, our air terminal tags are 2-3 lines, and list the size and mark, then CFM, and finally a typical number; for example:
18x18 CD-1
250 CFM
TYP 4
However for linear slot diffusers, we use 4 lines, i.e.:
24" LSD-1
4 SLOTS
250 CFM
TYP 2
To attempt to accomplish this using the same 3-line tag I use for all the other air terminals, I tried to code adding a new line using VB in the PSD that defines the top line. Here's the code that I'm using:
If "[TypeAbbreviationToggleSwap]" = "LSD" Then
RESULT = "[MvPartAir_TerminalStyles:Length]"" [Mark]" & VbCrLf & "[MvPartAir_TerminalStyles:Slots] SLOTS"
followed by some ElseIfs etc. to handle the non-LSDs.
Anyway, the VbCrLf (new line code) works fine, however, for some reason it changes the spacing between the (now) 2nd and 3rd lines. The dtext I used to make the tag was set to Bottom Center justification, so that when I add a new line to the top line, it bumps it up, rather than down, but for some reason, it still manages to squeeze the 2nd and 3rd lines ever so slightly together.
You can (hopefully) see in the attached screenshot what I mean: there is slightly less space between "6 SLOTS" and "100 CFM" than there is between the other lines.
It's a really nit-picky problem, I know, and I realize there are a few workarounds (such as just making a new tag-type only for LSDs, or moving the text up after adding the tag), but I was really hoping to get everything working with this one tag.
Anyone have any ideas why the spacing's getting messed up, and how to fix it? It may be a VB problem, or it may be a DTEXT problem, I'm not sure. (Perhaps does anyone know the 'new line' character code for dtext? (if one exists))
Just to clarify: the tag only contains 3 lines of DTEXT set to Bottom Center justification. The 4th line is 'artificially' added by adding a new line to the 1st line in the VB code defining the PSD.
Thanks for taking the time to read this tediously long post!
-Brad
