Results 1 to 6 of 6
Thread: Open Autocad to a specific folder
    2008-08
    Meriden, CT
    Default Open Autocad to a specific folder
    Is there a way to create a shortcut on a users desktop that will open Autocad and have the startup dialog box show a specified folder?
    Member crystalp's Avatar
    2005-08
    24
    Smile Re: Open Autocad to a specific folder
    I don't know if it's possible to do what you are asking, but this might be a suitable work-around:
    You can make AutoCAD start up automatically by doing these steps:
    Documents & Settings > Username > Start Menu > Programs > Startup - File > New > Shortcut. Browse to the .exe file you want to run and follow the wizard through.
    Then, once AutoCAD is open, you can have them type in CTRL-O or Open, and you will get a Dialog Box that will let you browse for drawings. In the Left hand side of the dialog box you will see links to your desktop and your documents, etc. You can add specific folders to this area by right clicking in the open space and choosing "add", or you can browse to the folder you want them to work out of and drag and drop it into that area. These "shortcuts" are saved, so the next time they go into AutoCAD they will still be there. They can be added or removed at will and are very handy if you have long file paths you don't want to be browsing to all the time.
    I hope this helps!
    0,0,0 The Origin
    8,028
    Default Re: Open Autocad to a specific folder
    Right-click the existing acad desktop icon, select Properties. Put the path to your desired folder in the "start in" box. In acad, set the variable REMEMBERFOLDERS to 0.
    You might want to make a copy of the existing acad desktop icon to work on.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Another useful trick is to map an available drive letter to a specific network folder.
    I have P: going to engineering/cad dwgs/
    2006-01
    Manchester,England, UK
    166
    I have a folder on my desktop called 'Jobs' which has a shortcut to every project I am currently working on. Then I have added the folder to the folders tab as shown on attached image.
    Gareth Spencer
    AutoCAD/LT-AutoCAD Civil 3D-AutoCAD Structural Detailing-Revit Structure/MEP
    http://becadsmart.blogspot.com/
    http://www.linkedin.com/pub/gareth-spencer/32/25/842
    Twitter: @becadsmart (Personal) @Garethcadline (Work)
    I could stop if I wanted to CadDog's Avatar
    2005-06
    So Ca
    411
    There is more than one way to skin a cat...
    Placing the path within the icon like "jaberwok" denotes was the way we did it here years ago. While this works great your desktop will get full very fast...
    I sure that the another ways work just as good but let's move on...
    The new way we do it at my company is by using AutoCAD's Sheet Set Manager.
    Not only are you able to access the directories you want but other working with you can using too...
    We also include the xref to the manager so you also know which xref to work on...
    KISS...
    Hope this helps...
    Here is a small sample:
    Jesse
    aka CadDog © 1994
    All is Well until It Fails
    Remember, that what you teach me here you are also teaching others...
  1. Replies: 2
    Last Post: 2007-02-04, 11:57 AM
  2. Add folder in file open/save
    By Andrew Dobson in forum Revit Architecture - General
    Last Post: 2006-08-07, 01:27 PM
  3. Saveas to open in current folder
    By jsr13 in forum AutoLISP
    Last Post: 2005-08-19, 04:34 PM
  4. Open EXPLORER to specific folder
    By LanceMcHatton in forum AutoCAD Customization
    Last Post: 2004-09-30, 09:15 PM
