Results 1 to 10 of 14
Thread: Problems adding Express Tools to the Ribbon
    2006-08
    Lake Charles, La.
    277
    Question Problems adding Express Tools to the Ribbon
    I've found several explanations online on how to do this. They are all the same. After downloading the revised acetmain.cui file:
    Copy the unzipped acetmain.cui file to your AutoCAD support folder (making a backup copy of the original version) - e.g.: C:\Documents and Settings\YOURNAME\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Support (WinXP)
    or
    C:\Users\YOURNAME\AppData\Roaming\Autodesk\AutoCAD 2009\R17.2\enu\Support (Vista)
    Run AutoCAD 2009 and start the CUI command
    In the top left panel, switch to the current workspace, so that its contents is displayed in the right panel:
    Click on the "Customize Workspace" button (turns blue)
    In the left panel, expand the tree "Partial CUI files" > EXPRESS
    Check the box by the "Ribbon Tabs" item
    In the top right panel, click the "Done" button and end the CUI dialog with OK
    I've done this several times, tried resaving my workspace, restarted '09 and I still cannot get it to take. After I've checked the box for the express tools and click 'ok', it constantly reverts back to being unchecked.
    What am I doing wrong?
    All AUGI, all the time gfreddog's Avatar
    2003-07
    Pequannock NJ US of A
    639
    Default Re: Problems adding Express Tools to the Ribbon
    Just tried it myself and got the same outcome, it doesn't take.
    I'd be interested in anyone's solutions.
    George V. Fournier Jr., CTS
    Sr. Sales Engineer - Autodesk Product Design Suite Premium 2014
    2006 AUGI DAWG (7th) - NJ AUGI Camp
    Volunteer Firefighter since 1985 & Bagpiper Wanna-be
    With the freedom of expression comes great responsibility
    2003-07
    639
    Quote Originally Posted by cwjean76 View Post
    or
    CWJean you may want to try posting this question in the CUI Forum http://forums.augi.com/forumdisplay.php?f=209
    Maybe they can help
    2003-07
    639
    Any ideas?
    2009-01
    I also have done everything mentioned above and yet the ribbon tab
    doesn't show the express tools.
    Does anyone have any solutions as I'm going insane trying to get Express tools
    to display on the ribbon tab.
    I've played around with the CUI but nothing seems to work.
    2006-08
    Lake Charles, La.
    277
    I still have had no luck.
    2004-08
    Hartford, Michigan
    3,086
    I just put everything in one area creating my own express tab using a custom flyout for all the tools, it seems to have worked just fine. After seeing it can be done, I'm going to add a panel/flyout for each submenu
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2006-08
    Lake Charles, La.
    277
    Quote Originally Posted by ccowgill View Post
    I've attempted to do the same. However, it doesn't want to seem to allow me to add a panel or flyouts to my ribbon. How did you accomplish this?
    2008-05
    161
    I don't remember where I downloaded the attached file but it worked fine for me.
    2003-07
    639
    Quote Originally Posted by icbinr View Post
    Eureka!
    I opened your CUI in the Transfer Tab and dragged your panels in the Ribbon Panels
    Then I created a new Ribbon Tab called Express and dragged the panels in and Vola' it worked.
    Very kewl
    Last edited by gfreddog; 2009-01-29 at 08:54 PM. Reason: Corrected my incorrect terms :-)
  1. Adding A Ribbon Tab?
    By mjdanowski in forum Revit - API
    Last Post: 2011-11-17, 12:02 PM
  2. Problems adding Express Tools to the Ribbon
    By cwjean76 in forum AutoCAD CUI Menus
    Last Post: 2009-01-29, 09:03 PM
  3. Resolving common issues / problems relating to Express Tools
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2006-09-09, 10:18 PM
  4. Express Tools - Layer Tools where are they?
    By Batman in forum AutoCAD General
    Last Post: 2006-04-27, 09:49 AM
  5. Problems installing Express tools
    By serpent6 in forum AutoCAD General
    Last Post: 2004-11-05, 09:24 PM
