Is there a way to get a plot stamp that only has the date? The one I have found has the plto date/time. I need one that only has the date.
Currently not possible.
The easiest workaround is to utilize one of your unused Project Information Parameters (Project Issue date would do the trick) and include that in your titleblock. Just prior to plotting you can change that value and it will update on all sheets.
7-years later, this is still not addressed? Does anyone even work in Autodesk's Revit division anymore?
