Thread: Getting the curb in my corridor to tie into existing
    2009-01
    9
    Default Getting the curb in my corridor to tie into existing
    Im working on my first Civil3D project. I had to teach myself how to use it and surprisingly have learned A LOT! I am rebuilding a city street that is approx 6 blocks long. All the curb will be replaced on this street but need to tie into existing curb around the radius' of adjacent streets. How do I make my curb go around the radius and stop, and then begin again at the next radius and continue down the street to the next adjacent street radius?
    I hope this makes sense.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Getting the curb in my corridor to tie into existing
    That's difficult to answer, because we don't really have any details about your project.
    But I suspect the easiest thing is to just use Feature Lines to model the curb returns.
    All AUGI, all the time Richard McDonald's Avatar
    2002-01
    At right angles to reality
    537
    Quote Originally Posted by sinc View Post
    I'm trying to do something similar. Its for a quick layout and cross sections for an existing road and want to add features to the corridor. Would the assembly not need to have target scripts in it for this to work? Is there a quick work around to assign an assembly to a feature line?
    Many thanks
    Richard
    2004-02
    Colorado
    1,986
    Again, that's difficult to answer, because you didn't really give details on what you want to do. If you are doing a mill & overlay, then there are assemblies for that. Otherwise, I'm not entirely sure what you are doing.
    For the OP, I was talking more about something like this:
    http://acecivil3d.blogspot.com/2008/...c-feature.html
    In the sample, Angel uses the new features in C3D 2009 to create dynamic featurelines from a corridor. He then creates the curb returns as additional feature lines, and hooks the endpoints of the curb return featurelines to they dynamic featurelines, from the corridor. This causes the curb returns to move dynamically up and down with the corridor, since as long as the featurelines are on the same site, they will take elevations from each other. So the curb return featurelines will move up and down with the dynamic featurelines, extracted from the corridor.
    This can work well if you just need a simple model, or if you don't need vertical curves along the curb returns.
    But you can also create alignments along curb returns, and use them as baselines in your corridor. This lets you do fancier things, with vertical curves along the returns.
    (And 2010 has some features that help even more with this...)
  1. Corridor Intersection Curb Return Problems
    By georgeh in forum AutoCAD Civil 3D - Corridors
    Last Post: 2012-05-03, 02:34 AM
  2. Adding a curb .rfa to an existing .rfa
    By the_cad_monkey in forum Revit MEP - Families
    Last Post: 2010-03-24, 07:52 PM
  3. Corridor contours don't tie into existing
    By William.Gares in forum AutoCAD Civil 3D - Corridors
    Last Post: 2009-12-30, 04:09 PM
  4. assembly with superelevation and existing curb tie-in
    By juanalacorina in forum AutoCAD Civil 3D - Corridors
    Last Post: 2008-09-05, 02:20 PM
  5. Connecting new corridor to an existing
    By reb_polum in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-08-10, 04:28 PM
