I have attached a dwg file that is 1.3mb. there are 6 line, 3 arcs, 1 linetype and only layer 0 and defpoints.
i have been through every filesize article on these and other forums. i have purged nested objects and regapps, checked for blank text boxes, exported to a dxf and resaved as a dwg and there are no layer filters... i even went so far as to delete the objects and the saved file was STILL 1.3mb.
i cannot wblock it out because it freezes my cad and crashes. i can't even copy and paste it into another drawing, because it freezes and crashes.
i HAVE created this object in a new file just by redrawing it... but i have other files to which this is happening. this particular dwg is a piece of equipment that we insert into a base drawing, and i only noticed the problem when after inserting it into the base the base file doubled in size... which i only noticed after i tried xreffing the base file into another drawing, which crashed.
i'm starting to suspect that one of the computers in the office is having some issues as it seems that files that get worked on with this computer come out with problems like this...
