Thread: Flat Oval Duct Fittings
    Member ewhitney's Avatar
    2002-05
    4
    Default Flat Oval Duct Fittings
    Using Autocad MEP 2009 with all the updates. I am trying to insert some flat oval duct fittings, but they do not seem to exist. Have tried to create my own, but seem to be having some issues with crashes and other errors. At one time there was a content builder webcast which is no longer available. I think Laura Gutwillig did the webcast (could be totally wrong). I cannot find another content builder webcast with all the specific steps for creating a parametric part.
    I have perused the forums and do not find anyone complaining about the lack of flat oval fittings, so I wonder if they really exist in the library and I just can't locate them. Specifically I am looking for the following parts:
    Flat Oval Bellmouth - to connect to a rectangular supply plenum coming from the air handling unit.
    Flat Oval Wye Fitting - what I can find in the library is about 10 feet long (not suitable)
    Flat Oval Cross - straight cross, conical cross & lo-loss cross with a ROUND BRANCH
    Flat Oval Tee - straight cross, conical cross and lo-loss cross with a ROUND BRANCH
    I have tried using a flat oval tee with the branch outlet having the same dimensions. (For instance, 35x26 flat oval tee with a 14x14 branch tap, hoping the program would recognize the branch as round, but the program wants to add a transition from 14x14 flat oval to 14 inch round.
    Does anyone else have these issues? Or is it just that I don't know where to look for flat oval fittings?
    I have attached PDF files for the specific fittings I am looking for. Although not indicated on the cut sheet for the tees, the branch outlets may be round just like the crosses.
    Any help would be greatly appreciated.
    Eric
    2007-10
    Tucson, Arizona
    613
    Default Re: Flat Oval Duct Fittings
    I have the following parts in the folder "C:\Documents and Settings\All Users\Application Data\Autodesk\ACD-MEP 2009\enu\Aecb Catalogs\US Imperial\Duct\Oval":
    (see screenshot)
    -Buzz
    2002-05
    4
    It is my belief that all the fittings in the following links should come with the program Out Of The Box. (I could not upload them & you may have to register to obtain access). I have no idea where Autodesk got the information for the fittings in ductwork catalogs, but a vast majority of the high pressure ductwork is being specified as United McGill and most other ductwork fabricators use United McGill as the basis of their fittings.
    United McGill as far as I know has done way more research on duct fittings, pressure drops, etc. I am not sure why Autodesk does not use the United McGill catalog as the basis of all their fittings in Autocad MEP. Just look at the submittals for the next high pressure job you are involved with and see if they don't match.
    http://www.mcgillairflow.com/textDoc...dimensions.pdf
    2007-10
    Tucson, Arizona
    613
    Here is the "oval duct" content available from seek:
    http://seek.autodesk.com/#query=sear...%253Doval+duct
    -Buzz
  1. Flat Oval duct Profile missing
    By mrypdahl in forum Revit MEP - General
    Last Post: 2011-04-08, 05:31 PM
  2. Flat Oval Duct
    By ddeneve in forum Revit MEP - General
    Last Post: 2010-01-13, 11:23 PM
  3. Flat Oval Duct
    By aosterday in forum Revit MEP - Wish List
    Last Post: 2008-05-13, 04:50 PM
  4. Flat oval ductwork
    By awascher in forum Revit MEP - Wish List
    Last Post: 2008-01-16, 02:20 PM
  5. Flat oval ductwork
    By Michael.c in forum Revit MEP - General
    Last Post: 2007-06-12, 02:16 PM
