Thread: Shade toggle shortcut
    I could stop if I wanted to Ron Oldenbeuving's Avatar
    2004-06
    Lewiston, South Australia
    291
    Question Shade toggle shortcut
    Does anyone know of a keyboard shortcut or macro for quick toggling of shade/wire frame. I find having to use the mouse to pick and click the appropriate mode time consuming when a single keystroke would be much simpler. Any help greatly appreciated. Regards, Ron Oldenbeuving.
    2015-12
    Arizona
    2,478
    Default Re: Shade toggle shortcut
    You might have to program it yourself from the
    on screen clues. As an example to toggle a view mode
    in regular AutoCAD, you need to write a macro button
    or edit your pgp file to include ALT+V 3 T to toggle to
    Top View.
    What keyboard short-cut hints does Inventor offer you?
    2004-06
    291
    Thanks Mike. I currently have Ctrl+` for shaded, Shft+` for shaded with edges and Ctrl+Shft+` for wire frame. I was hoping to set up a key to toggle between these three. Unfortunately, I'm a complete amateur when it comes to writing macros. I'm just gonna have to learn I suppose. Any tips from anyone would be greatly appreciated.
    Member sanjay_yallure's Avatar
    2004-08
    India, Ahmedabad
    10
    Use below macro & assign NUM 1 key to it them you can toggle by pressing NUM 1 key from the numaric key pad
    Sub ToggleShade() '************TEsted*************** ***NUM 01***
    Dim oView As View
    Set oView = ThisApplication.ActiveView
    If oView.DisplayMode = kHiddenEdgeRendering Then
    oView.DisplayMode = kWireframeRendering
    ElseIf oView.DisplayMode = kShadedRendering Then
    ElseIf oView.DisplayMode = kWireframeRendering Then
    End If
    oView.Update
    End Sub
    Sanjay Yallure
  1. Replies: 6
    Last Post: 2017-03-23, 03:02 PM
  2. Shortcut Key to Toggle "Predict Offset" when Constraining
    Last Post: 2014-01-10, 04:04 PM
  3. Is there a Keyboard Shortcut to Toggle a Specific Category?
    By eanastas362758 in forum Revit - Platform
    Last Post: 2013-03-20, 05:37 PM
  4. Toggle tabs from clash via Keyboard Shortcut
    By bparrell in forum NavisWorks - Wish List
    Last Post: 2009-08-04, 06:50 PM
  5. Slope Defining Toggle should act like Constrain Toggle
    By gregcashen in forum Revit Architecture - Wish List
    Last Post: 2004-01-15, 10:17 PM
