Thread: Polygon Callout
    2003-09
    Honolulu
    39
    Smile Polygon Callout
    Hi,
    can we make a polygon callout in REVIT 7.0?
    Thanks.
    Autodesk Revit Client Support Manager slb's Avatar
    2003-07
    Waltham, MA
    107
    Default Re: Polygon Callout
    Call-outs need to be, basically, rectangular. They can have rounded corners on them, which could be made to look more like an oval (circle) than a rectangle if the corner radius is enlarged enough.
    The call-out view can be cropped only with a rectangular shape... Any other type of cropping would need to be simulated with a filled region.
  1. I wish the Callout tool had the ability to make the callout boundary any shape.
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2017-10-13, 10:14 PM
  2. Polygon Scope Box
    By Beginner Revit User in forum Revit MEP - General
    Last Post: 2015-01-15, 09:06 PM
  3. Stretch a Polygon/Maintain the Original Area of Polygon
    Last Post: 2007-08-02, 04:39 PM
  4. 2D Polygon generation w/ VBA
    By joeposton in forum VBA/COM Interop
    Last Post: 2004-12-07, 10:30 PM
