Thread: Layer freeze in ALL viewports
    2007-08
    3
    Angry Layer freeze in ALL viewports
    Vplayer is one of my favorite commands. With ACAD MEP 2008, I used to be able to freeze a layer in all viewports in the project. Now I am working with MEP 2009 and I am only able to freeze a layer(s) on the current tab I am working on. This slows me down quite a bit if i would want a certain layer to be shown in only 1 viewport. Does anyone know of a way to freeze layers in numerous viewports on numerous tabs?
    Active Member drafting1's Avatar
    Atlanta, Ga
    85
    Default Re: Layer freeze in ALL viewports
    If you want to freeze a layer in all viewports, go up to the toolbar and select the layer
    pulldown. First make sure the layer you want to freeze is not the current layer, then find the layer you want to freeze and click Freeze in All Viewports (next to
    the lightbulb). That should do it.
    2009-01
    17
    Quote Originally Posted by matthew.g View Post
    This is why I do not use separate layouts in paperspace. I have all my viewports in ONE layout, then when I use VPLAYER freeze I type in layers I want frozen and select viewports to freeze those layers with a crossing window.
    I am not a fan of using multiple layers for that very reason.
  1. 2014: New Layer .... Freeze in all new viewports
    By tim_newsome in forum AutoCAD General
    Last Post: 2014-06-16, 02:43 PM
  2. 2012: Copy Layer but Freeze in Viewports
    By vweavers in forum AutoCAD General
    Last Post: 2013-07-03, 10:21 AM
  3. Copying Viewports & Layer Freeze
    By lmnop in forum AutoCAD General
    Last Post: 2008-01-27, 11:02 AM
  4. Replies: 3
    Last Post: 2008-01-17, 01:08 PM
  5. Freeze in all viewports
    By cboisvert in forum AutoCAD General
    Last Post: 2005-05-17, 10:56 AM
