Thread: 1-line and 2-line pipe fitting display
    2007-08
    St. Louis
    51
    Angry 1-line and 2-line pipe fitting display
    I have been studying the Display manager and the functions of it for the past week. Please shoot me now! I am having one heck of a time getting the piping fittings to show correctly or at least the way I would like them.
    I have set up the Piping systems to show 1-line for pipes that are 3-1/2” or smaller and 4” inches or larger to show 2-line. I have that controlled in the pipe system definition. 1-line pipe fitting representation shows fine but the 2-line representation doesn’t, it shows the pipe end also.
    I have tried to delete the 2-line rise/drop style but it then show a different 2D representation and it is 180* out.
    If I turn off the 1-line layer setting in the “plan set” then the 2-line looks good but I lose all the single line fittings. If I turn off the contour layer settings in the “plan set” then I still get a circle in the 2-line fitting.
    I cannot figure out how to get a good 1-line and 2-line representation in the same plan.
    How are you guys doing it? Or are you?
    BTW I'm using MEP2008
    ATP Manager CADKitty's Avatar
    The Dragon's Lair
    731
    Default Re: 1-line and 2-line pipe fitting display
    The way we're handling it is like your first bmp attachment - you see the drops, fittings, etc. on the 2-line piping. It took us a while to get used to it but if there's one thing we're learning about MEP it's that we need to be open to a new way of graphically displaying our linework.
    I drink coffee for your protection.
    Windows 7 | AutoCAD 2017 | Revit 2017
    2007-08
    St. Louis
    51
    Talking Re: 1-line and 2-line pipe fitting display
    Well after a very painful couple of weeks I have figured it out.
    I started with the OOTB “Pipe Rise Drop Styles”, I made copies and renamed them for our use. I used “Pipe Break – Patterned Rise Only” and “Pipe Break – Rise Only”, because they where the ones tied to the OOTB pipe systems. I could never get them to work with a display showing both 1-line and 2-line in the same drawing. I had beaten my head for two weeks trying different setting to get what we wanted with no avail.
    Today I tried a different rise/drop style, the “PIPEROUNDRISEDROP”. I made a copy of it and I also copied the “Aecb_Default_Rnd_2Line_Drop” block in the template. I modified the copy of the block by deleting all the content in it and saving. Under "Circular Drop 2-Line" on the “Rise and Drop” tab I specified for “Block:” the new modified block. I also added a new Symbol Line for Circular Drop 1-line Tee. After all that it worked exactly like we wanted (see attached image). For whatever reason this method would not work in the “Pipe Break – Patterned Rise Only”.
    I hope someone will find this useful and if you have any question feel free to ask.
  1. Replies: 3
    Last Post: 2013-11-10, 12:21 AM
  2. 2012: Single Line Pipe Fitting Scaling
    By ktbeane167828 in forum Revit MEP - Families
    Last Post: 2012-04-09, 04:56 PM
  3. Size of Single Line Wye Pipe Fitting
    By i2mikee in forum Revit MEP - General
    Last Post: 2010-07-13, 08:11 PM
  4. Fitting not breaking pipe in single line
    By BigBadBIM in forum Revit MEP - Families
    Last Post: 2009-02-03, 08:37 PM
  5. Plumbing Line Fitting Display
    By a.armiger in forum AMEP General
    Last Post: 2008-11-20, 10:25 PM
