Results 1 to 10 of 14
Thread: Layer Manager open on ACA startup?
    Active Member CAtDiva's Avatar
    2007-10
    Where pedals spin to move wheels
    58
    Default Layer Manager open on ACA startup?
    My layer manager (classic style) opens during the startup process - where do I go to remove this from the startup set?
    Additional background: At one point I ran my ACA 2009 as ACAD. During this time, I was able to open the layer palette with the "layer" command. Then I must have closed the program with the palette open. Since then, I have run as both ACA and ACAD in "classic" workspace (exploring new features), hence convering the "layer" command to the classic manager.
    Thank you!!
    2007-10
    58
    Default Re: Layer Manager open on ACA startup?
    Well, I backtracked: set ACAD profile current; made sure the palette was turned off; closed and reopened ACA; set profile back to working profile; closed and reopened ACA again and the layer manager did not open with it.
    Nonetheless - does anyone know where that list of what opens when ACA/D opens lives? It would be nice to know in case there's something that is not so easy to backtrack on happens.
    2007-10
    58
    Quote Originally Posted by CAD'iva View Post
    Thank you!!
    Ok - I still would like to know where this information lives. I have redone my LA shortcut to the LAYERPALETTE because 90% of what my users do with layers is freeze and thaw, which the palette lets you do dynamically. But if that is left open when someone exits, the next time they enter the layer manager opens instead because the LAYER command is in the startup path. Or perhaps I need to set it up so that the layer palette is closed automatically upon exiting. Anyone know how to do that?
    2006-12
    Big "D"
    3,709
    It sounds like you have your workspace settings to automatically save changes. Click on the cog looking icon in the bottom right tray and select workspace settings. Clear "automatically save workspace setting". You can manually save them if you ever make changes.
    See if that works.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2007-10
    58
    Quote Originally Posted by dzatto View Post
    See if that works.
    Nice suggestion - unfortunately it didn't work . . .
    100 Club red2002yzfr1's Avatar
    2002-04
    Allentown PA
    141
    Having the same problem - exactly the same problem. I do want the Layer Palette to be part of my palettes when starting up, but the classic window opens on startup and not the palette. I go into the CUI and even tell it not to open and it still does. Changing the command seems to be the answer, but where, hmmmmm.
    2002-04
    Allentown PA
    141
    Does anyone know where these highlighted commands are coming from? This is all from my dialog box at startup.
    Loading AEC Base Extended...
    Loading AEC Base UI...
    Loading AEC Project Base...
    Loading AEC Base GUI...
    Loading AEC Schedule Data...
    Loading AEC Architectural Base...
    Loading AEC Project UI...
    Loading AEC Utilities...
    Loading AEC Layer Manager...
    Loading AEC Workflow Utilities...
    Loading AEC Schedule Data UI...
    Loading AEC Schedule...
    Loading AEC Schedule UI...
    Loading AEC Structural Base...
    Loading AEC Structural UI...
    Loading AEC Project Palette...
    Loading AEC Area Base...
    Loading AEC Architectural UI...
    Loading AEC Annotations UI...
    Loading AEC Dimensions Base...
    Loading AEC Dimensions UI...
    Loading AEC Recipe Base...
    No default component database set.
    No default keynote database set.
    Customization file loaded successfully. Customization Group: ACAD
    Customization file loaded successfully. Customization Group: CUSTOM
    Customization file loaded successfully. Customization Group: IMPRESSION
    Customization file loaded successfully. Customization Group: AUTODESKSEEK
    Customization file loaded successfully. Customization Group: DBCONNECT
    Customization file loaded successfully. Customization Group: CONTENTSEARCH
    Customization file loaded successfully. Customization Group: SPURGE
    Customization file loaded successfully. Customization Group: EXPRESS
    Checking for object enablers on the Autodesk website
    Substituting [simplex.shx] for [archstyl.shx].
    Regenerating layout.
    Command:
    Command:
    AutoCAD menu utilities loaded.
    AutoCAD Architecture menu utilities loaded.*Cancel*
    Enter command name:
    Command: Loading AEC Publish UI...
    _ToolPalettes
    Command: _RIBBON
    Command: properties
    Command: TOOLPALETTES
    Command: EXTERNALREFERENCES
    Command: Layer
    Duplicate definition of block _ArchTick ignored.
    Command: adcenter
    ADCENTER Loading MEP Base...
    Loading MEP Electrical Base...
    Loading MEP COLE Base...
    Loading MEP HVAC Base...
    Loading MEP Pipe Base...
    Loading MEP Plumbing Base...
    Command:
    2007-10
    58
    [QUOTE=red2002yzfr1;1006673]Does anyone know where these highlighted commands are coming from? This is all from my dialog box at startup.
    Command: _RIBBON
    Command: properties
    Command: Layer
    [\QUOTE]
    Just to clarify, you want to know where they are set (so you can change "Layer" to "Layerpalette"), not what they're doing (i.e. opening the various palettes when ACA starts up), right?
    Unfortunately, I don't know the answer anymore than you - that's essentially the question I've been trying to ask since starting this thread. I gave up on the layer palette and usually forget it exists more often than not. (Still running ACA 2009.)
    2002-04
    Allentown PA
    141
    Yep, Yep & Yep. I want LAYERPALETTE, not LAYER on startup.
    2002-04
    Allentown PA
    141
    I ran the update that Autodesk has sent out and NOT fixed.
  1. layer manager will not open
    By dcochrane757156 in forum AMEP General
    Last Post: 2011-03-14, 03:32 PM
  2. 2011: Layer properties manager at startup ???
    By EDDemtec in forum ACA General
    Last Post: 2011-03-07, 02:10 PM
  3. Open Layer Manager without a Layer selected
    By msjca in forum AutoCAD General
    Last Post: 2006-11-28, 04:23 PM
  4. Layer Manager will not open
    By stelthorst in forum AMEP General
    Last Post: 2006-06-16, 07:57 PM
  5. Layer Manager & Layer drop down are slow to open.
    By Glenn Pope in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-17, 05:01 PM
