Thread: What would be your' one best piece of advice?
    100 Club kleenhippie's Avatar
    2002-08
    38.7867 N, 77.4917 W
    129
    Cool What would be your' one best piece of advice?
    I have just been upgraded from Vanilla CAD 2008 to "AutoCAD Revit MEP Suite 2009", with a new computer to boot.
    Being the only MEP coordinator/CAD guy in this Co. for the last 3 1/2 years I've come to depend on AUGI forums for advice and some instruction. I've always found alot of wise and not so wise, good and not so good help and advice.
    Now with this upgrade I'm scratching my head wondering what is the most important thing I need to know and do to make this transition. While the work load lately is lighter than in the past few years, being in the DC area I'm still busy and can't take much of a break to properly learn what I must.
    My question is; what would be the most important thing you feel I should know and do to make the transition?
    As always I thank you all for your wise and sage advice.
    100 Club cris8096's Avatar
    2008-02
    116
    Default Re: What would be your' one best piece of advice?
    Have a truly positive open mind about Revit MEP, it's still maturing
    Mechanical Designer
    San Francsico, CA
    2008-07
    203
    If you're beginning to use Revit forget everything that you know about ACAD. And as chris said you are going to have to be patient, Revit has a learning curve, and the curve is constantly moving as the software matures.
    If I were you I would contact your reseller and see if they can give you any literature on topics such as setting up projects, or workflows, etc.
  1. DI T-Piece
    By Happyunited in forum Revit MEP - General
    Last Post: 2011-06-14, 03:38 PM
  2. étiquette de pièce - dimensions de pièce
    By jmcouffin in forum Revit Architecture - Général
    Last Post: 2010-02-25, 09:54 AM
  3. Périmètre de pièce =0 dans nomenclature de pièce
    By vb.156750 in forum Revit Architecture - Général
    Last Post: 2009-11-11, 12:25 PM
  4. Limite de piece
    By revitteam in forum Revit Architecture - L'art et la manière
    Last Post: 2009-03-03, 08:36 PM
  5. Reverse Curves with tangential piece (can we remove tangential piece)
    By dkuhn in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-06-11, 11:11 AM
