Thread: Plotting problem
    2004-08
    Default Plotting problem
    Using LDD 2009 Companion
    When plotting and I want to change the plot style table file, the files do not show up.
    I checked in the correct directory and the files are there. Is there any place else I can check to get this to work?
    Houston
    7,543
    Default Re: Plotting problem
    Run the CONVERTPSTYLES command. You are in a drawing that uses STB and all you have are CTB (or vice-versa).
  1. Plotting Problem
    By toms.247786 in forum AutoCAD Civil 3D - General
    Last Post: 2010-04-14, 04:08 PM
  2. plotting problem
    By dgt.mantis in forum AutoCAD General
    Last Post: 2009-02-20, 04:18 AM
  3. Help!!! Plotting Problem
    By Tbird2298 in forum CAD Management - General
    Last Post: 2008-02-24, 01:04 AM
  4. Plotting Problem
    By BCrouse in forum ACA General
    Last Post: 2006-09-28, 03:55 PM
  5. Plotting Problem
    By lbragg in forum AutoCAD General
    Last Post: 2004-08-03, 07:26 PM
