Thread: Drawing status bar icons in AutoCAD 2009
    2008-03
    43
    Default Drawing status bar icons in AutoCAD 2009
    Can anyone tell me if there is a system variable that controls which icons are present on the drawing status bar (Annotation scale, Annotation visibility & AutoScale) in ACAD 2009? I am aware that these can be turned off via the button at the far right of the status bar but I would like to set this on startup.
    Thanks.
    Eddy Bussiere
    smp engineering
    www.smpeng.com
    100 Club amaser's Avatar
    2006-05
    Joliet, IL
    105
    Default Re: Drawing status bar icons in AutoCAD 2009
    this might be a late reply, but if you turn them on/off as desired, then save the workspace to a name, and set that workspace to active at startup, that will work.
    i have created my own workspace called 'default' with my toolbars, ribbons, and options set, and i have a startup lsp file wich says (set wscurrent = 'default') and that loads every dwg with my workspace, and my options set
  1. Transparency with custom AutoCAD 2009 icons
    By swells.132024 in forum AutoCAD CUI Menus
    Last Post: 2009-09-28, 03:01 PM
  2. Making and editing icons for AutoCAD 2009
    By swells.132024 in forum AutoCAD Customization
    Last Post: 2009-03-20, 02:51 PM
  3. Restrict AutoCAD 2009 to one drawing per session
    By dave.wright in forum AutoCAD General
    Last Post: 2008-06-25, 01:33 PM
  4. AutoCAD 2009 help needed with a PIPE ISO drawing
    By CAD CHICK MTY in forum AutoCAD General
    Last Post: 2008-05-01, 06:35 PM
  5. AutoCAD 2009 Tray Icons
    By Grumpy in forum AutoCAD General
    Last Post: 2008-04-25, 05:38 PM
