Thread: Extract data from Dynamic block with attributes
    2007-09
    6
    Smile Extract data from Dynamic block with attributes
    HI!
    I am looking for a lisp programme that will help me to extract data in .xls format or just in Tabular format in Cad 2009.
    I am looking to extract data from Dynamic block with attribute.
    i want to get the data in a tabular form showing the block name, length of the block/Line,
    nos, etc from that block.
    please Help,
    Regards,
    Mahesh Darekar
    2007-08
    171
    Default Re: Extract data from Dynamic block with attributes
    Hi,
    Why not using the EATTEXT command ?
    2007-09
    6
    Thumbs up Re: Extract data from Dynamic block with attributes
    Thanks dear, Nice to know such a good command exists in Autocad.
    This command works very well,
    I do need to customise many things but more than half a battle is already covered by this.
    thanks for your quick reply.
    i thought i will not get a single reply for this post but i am happy that u have done it.
    I will try the rest part of it and if any problem i will definately get back to u for help.
    Thanks once again
    Regards,
    Mahesh
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,776
    From the forum guidelines: :Provide a short but catchy description of the issue you are posting in the Subject field of the message." You can read them in the FAQ menu above.
    Its the goal of the forums to help everyone. So if you use descriptive titles, others will benefit. Imagine trying to read through threads if everyone just said "Help".
    C:> ED WORKING....
    2007-09
    6
    Smile Re: Extract data from Dynamic block with attributes
    Dear sir,
    I will definately go through the guidelines and next time i will follow the same.
    thanks for your advise. It will definately help everyone to know what Topic is been discussed.
    Thanks & Regards,
    Mahesh D.
  1. Replies: 2
    Last Post: 2012-06-06, 12:28 PM
  2. importing data into block attributes
    By tparvind in forum AutoCAD Customization
    Last Post: 2011-06-27, 09:46 PM
  3. Extract Title Block Attribute Data to Excel
    By bzrqmy in forum AutoCAD Customization
    Last Post: 2008-12-03, 07:57 AM
  4. Replies: 21
    Last Post: 2007-03-20, 02:03 PM
  5. Extract Dynamic Block Attributes, values change as Block changes
    By dave.buckberry in forum Dynamic Blocks - Technical
    Last Post: 2006-09-05, 04:38 PM
