Thread: Vista 64 Export to ODBC trouble
    I could stop if I wanted to arqt49's Avatar
    2007-07
    London, UK
    337
    Default Vista 64 Export to ODBC trouble
    Maybe this should go to a ODBC forum...
    I can´t export from revit to a MS Access file in Vista64.
    I've been searching for a solution and only found that those drivers exist in a different directory. The trouble seems to be in the MS drivers.
    Only MS SQL server drivers are available, and I have no use for those.
    Has anyone had the same problem, and found a solution?
    100 Club vgonzales's Avatar
    2006-01
    New Haven, CT
    134
    Default Re: Vista 64 Export to ODBC trouble
    Limitations
    As of this Revit release, Microsoft has not made available ODBC (Open Database Connectivity) drivers for its 64‐bit operating systems. Consequently, the Revit 64‐bit platform cannot export a Microsoft® Excel®‐ or Microsoft Access®‐compatible ODBC file. (Ref: Revit 64 release notes.pdf)
    Gonçalo Feio.
    I think you are out of luck for now. I do not think it can be solved anytime soon.
    Regards,
    Leo
    Virgilio Gonzales, AIA
    "Stop drawing! Start Building!"
    HP ProBook 4730s, Win 7 Pro x64 SP1, Intel Core i7-2630QM 2.00 Ghz, 8 GB RAM, Revit Arch 2012 WU-2 & 2013 WU-2
    2005-07
    Somewhere in the BIM world
    3,140
    You can install the 32bits version of RAC and use that. I usethat 32 bits for the Naviswork export since it doesnt run under x64
  1. ODBC export to Excel
    By avoss in forum Revit Architecture - General
    Last Post: 2007-03-22, 05:25 PM
  2. ODBC Export
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2004-02-24, 10:34 AM
