Thread: Moving viewports causing slow response
    2006-08
    Lake Charles, La.
    277
    Default Moving viewports causing slow response
    My co-worker and I have noticed that with 2009 when you attempt to move a viewport and after you have picked your basepoint, AutoCAD slows to a crawl. Its like SuperSnap has been turned on! Can anyone tell me why this is and if there is something that can be done about it? .....it's very annoying.....Thanks
    2005-01
    Sheffield -UK
    49
    Default Re: Moving viewports causing slow response
    Try turning off the first viewport:
    hightlight viewport
    select properties
    Misc>ON =No
    the display will turn off
    then copy the OFF viewport which should be quicker.
    Turn on both viewports as above:
    Misc>ON =YES
    This may take a while to regenerate but the copying process will be much quicker.
    As a tip if you have files with many "large" viewports which opens really..... slowly.... try saving the file when some/all of the viewports have been turned off and then turn on as and when etc.
    Hope this helps
    Geoff Olner
    Architectural Images -Sheffield (UK)
    2004-08
    Hartford, Michigan
    3,086
    Quote Originally Posted by cwjean76 View Post
    is your layer palette open? if so close it, slowness should go away.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2006-08
    Lake Charles, La.
    277
    Quote Originally Posted by ccowgill View Post
    That was the issue!
    I had mine parked as a flyout on the left of my screen. Why does it use up so much resources? Is this just a bug?
    Thanks
    2004-08
    Hartford, Michigan
    3,086
    That was the issue!
    Thanks
    yes, its a bug, no fix for it yet.
    Windows 7 Pro x64
  1. HELP! Very slow keyboard response
    By ralph.burkey in forum AutoCAD General
    Last Post: 2009-03-25, 09:56 PM
  2. Slow keyboard response
    By john.113502 in forum AutoCAD General
    Last Post: 2008-01-25, 05:14 PM
  3. Very slow response speed in Inventor Pro 11 & AutoCAD 2007
    By alfred.putter in forum Inventor - General
    Last Post: 2007-04-24, 01:25 AM
  4. Replies: 2
    Last Post: 2007-02-14, 06:13 PM
  5. Slow dialog response in AutoCAD 2006
    By Sid in forum AutoCAD General
    Last Post: 2006-02-08, 02:28 PM
