This is a new one. The center to face spacing is inconsistent with the outlet OD so each outlet size will have its own dimension along with the main body dimensions. I am familar with csv files. How do I get the Formulas to identify the nominal size then the outlet size?
IE a 2" tee has four smaller outlet sizes. How to get the read to hit the nominal size then the smaller sizes? Does the csv file need a specific format? I have the column (Nominal Size) with every listing entered IE 2" four times. Column (Outlet Size) with each size ascending .75, 1 ,1.25, 1.5. Column (CenterSpacing) for each row has a different length 1.75",2",2.25",2.375". I haven't come across a how to for this one?
