Results 1 to 10 of 16
Thread: How do you load a ARX file?
    Active Member zorroxxxx's Avatar
    2002-12
    92
    Question How do you load a ARX file?
    I was searching the web for LISP files and came across an interesting ARX file which draws 3D Bolts. I have never heard of a ARX file extension.
    What are they?
    Are they somewhat like Diesel or Scripting files?
    Can some one tell me how to load one of these files?
    Thanks in advance!!!
    Gary
    2015-12
    Arizona
    2,337
    Default Re: How do you load a ARX file?
    Type APPLOAD and then browse to the location of
    that ARX application.
    2000-01
    Seattle WA USA
    5,857
    Quote Originally Posted by zorroxxxx
    … I have never heard of a ARX file extension.
    What are they?
    Gary, they are programs written in C++ and compiled using the ObjectARX SDK. The advantage to them is that AutoCAD considers them to be extensions of itself (think speed and access to the guts of AutoCAD).
    150700
    3,434
    You can also load .arx files the same way you load .lsp files, through the load/unload applications dialog. Type appload at the prompt and follow the dialog box. You can also add it to the start-up suite so it loads everytime. I think this is the simplest way to do it, although there are other (better??) ways to do this
    I could stop if I wanted to LanceMcHatton's Avatar
    2002-04
    Las Vegas, NV, USA
    299
    Is there a way to load .arx files from the command line?
    Lance McHatton
    AutoCAD 2018
    Windows 10
    I swear, I did not dado that rabbet.
    13,626
    Hi
    Use the _.ARX command ie.
    Command: _.ARX
    Enter an option [?/Load/Unload/Commands/Options]: _L (setting system variable FileDia = 0 will force command line entry, instead of "Select ARX/DBX File" dialog box opening)
    OR
    Look at the AutoLISP function "arxload"
    OR
    Have a good one, Mike
    2002-04
    Las Vegas, NV, USA
    299
    Quote Originally Posted by Mike.Perry
    Hi
    Command: _.ARX
    OR
    I just discovered the ARX command and entered that into my LISP file. However, since it's better to use LISP functions as opposed to commands, I will try out the ARXLOAD function.
    Here's my command code if anyone's interested:
    (command "arx" "l" "C:\\progra~1\\LandDe~2\\Express\\dwglog.arx")
    Thanks, Mike!
    Lance McHatton
    AutoCAD 2018
    Windows 10
    2002-12
    92
    Talking Re: How do you load a ARX file?
    Thanks to all that replied.
    I have it working. It was not what I was looking for, but at least I learned about the ARX file.
    Gary
    2009-06
    18
    When I tried this in 2008, my command line echos:
    Command: (command "ARX" "L" "C:
    And I have to hit ESC to restore any operation. Apparently, it does not like the c:\path as far as I can tell.
    Houston
    9,351
    Quote Originally Posted by caddcop View Post
    Either use double back slashes or a single forward slash.
    (command "._ARX" "_L" "C:\\mypath\\myarx.arx")
    ;; --or--
    (command "._ARX" "_L" "C:/mypath/myarx.arx")
    R.K. McSwain | CAD Panacea |
  1. Exporting to CAD from Revit (Preset .txt file to load? ctb file?)
    By goodtastingsteak in forum Revit - Plotting/Printing/Exporting
    Last Post: 2015-03-13, 05:34 PM
  2. arg. profile file won't load
    By Mac Demer in forum AutoCAD General
    Last Post: 2009-07-15, 08:15 PM
  3. How to Load a Linetype file?
    By BeKirra in forum AutoLISP
    Last Post: 2008-11-05, 10:36 PM
  4. DXF file won't load in ACAD
    By jwongmep in forum AutoCAD General
    Last Post: 2008-08-08, 07:08 PM
  5. Vue 6 Infinite- Won't load file
    By mikethayer in forum DV - The 3rd Dimension
    Last Post: 2007-10-01, 10:35 PM
