Thread: Revit MEP 2009 and Point Clouds?
    I could stop if I wanted to Dr._House's Avatar
    2007-07
    Milwaukee, WI
    218
    Default Revit MEP 2009 and Point Clouds?
    Can Revit MEP 2009 open and interact with Point Clouds generated by a 3D survey scan, or is it not quite there yet?
    2002-02
    St. Louis, MO
    4,695
    Default Re: Revit MEP 2009 and Point Clouds?
    It can use a set of DEM points. Quite common in the survey biz. I'm not sure if this is the sort of data format you are refering.
    2007-07
    Milwaukee, WI
    218
    I am not in the Survey biz at all, but I know that the company we're working with has a 3D scanner that can Survey a building and then that either spits out a Point Cloud, or they can model it for us and give us the model.
    Getting the Point Cloud from them would be cheaper and allow us to model it our own way, but I do not think Revit is Capable of opening up a point cloud just yet.
    2005-06
    87
    I've imported Point Clouds that were converted into autocad first. They had to be small because the amount of points slowed down view changes.
  1. 2015: Point clouds to usable Revit model
    By matt__w in forum Revit MEP - General
    Last Post: 2014-12-15, 06:06 PM
  2. 2014: Major Flaw in upgrading Point Clouds from Revit 2013 to 2014
    By stellarblue153 in forum Revit Architecture - General
    Last Post: 2014-10-14, 01:51 PM
  3. 2014: What are Point Clouds?
    By FBL - Desirea in forum AutoCAD Civil 3D - General
    Last Post: 2013-10-29, 08:51 PM
  4. 2013: Revit, Point Clouds - is there a simple surface or mesh solution?
    By t.eugene.lee285564 in forum Revit Architecture - General
    Last Post: 2013-08-11, 11:57 AM
  5. Discrepancies using Point Clouds in Revit Architecture
    By dfluegeman in forum Revit Architecture - General
    Last Post: 2012-04-13, 02:17 PM
