Thread: generic model , void form, void extrusion
    2006-04
    418
    Default generic model , void form, void extrusion
    i was placing on the fce of a brick wall and (i think) i had it past the face (into the wall 1") and a little outside the wall.....when i used the cut geometry tool everything seemed to be fine but then it appeared as if i had cut holes in it....reveal was meant to be a pattern of rectangles in wall surface .... i wanted the brick pattern to be visible at the back of the recess and it wasn't
    All AUGI, all the time Katika's Avatar
    2004-07
    Perth Australia
    736
    Default Re: generic model , void form, void extrusion
    I've never seen a reveal with a pattern in it in Revit, I thought the reveal profile simply ran the length or height of the wall.
    If the familiy does indeed have some kind of [patterning, I would think it would be set to be visible only in fine detail level, so perhaps change that, else edit the family and check it.
    It's very hard to determine the actual issue without the file (or at least screenshots)
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by ntnik View Post
    Use the paint bucket and paint it with the pattern you want.
    Andre Carvalho
    2006-04
    418
    thanks.... would post pdf to view....but i got frustrated and undid the work....i will post if the paint bucket doesn't do the trick....i think if i just set down for one day and learn what all the buttons do i would be better off
  1. 2009: Void Extrusion
    By SBH1730 in forum Revit Architecture - General
    Last Post: 2012-03-07, 01:03 AM
  2. Changing Void to Extrusion
    By Alex Page in forum Revit Architecture - Families
    Last Post: 2010-09-14, 01:19 AM
  3. Void Extrusion
    By r.c.russell in forum Revit - Student Support
    Last Post: 2009-06-13, 10:15 AM
  4. Void extrusion help
    By Kirk Bricker in forum Revit Architecture - Families
    Last Post: 2006-05-02, 11:01 PM
  5. Cut Geometry, Solid form, Void form
    By mmolina in forum Revit Architecture - General
    Last Post: 2005-05-11, 09:33 PM
