Results 1 to 9 of 9
Thread: Rendering with a Transparent Image Toposurface?
    Default Rendering with a Transparent Image Toposurface?
    Is it possible to create a rendered 3d view with a transparent toposurface? I am trying to create an image that shows a building on a hill side that shows the topo/grade and the retaining walls, grade beams and drilled piers under the surface? I can export to an Image and get transparency of the toposurface, but it is not rendered. Should this be in General rendering forum? Also, I am have some crashes with High quality renders, should I post that in some other forum, like hardware?
    Jeff
    2006-05
    836
    Default Re: Rendering with a Transparent Image Toposurface?
    Have you tried creating a floor with a large thickness and then using the warping slab tool??
    Not the fastest way but gets the job done and works great with tunnel and under ground structures.
    AJS
    BIMM Consultant
    www.GHD.com
    2008-07
    Brisbane (Ex. Swedish)
    349
    Do't have revit infron of me so i may be wrong here - but can't you assign transparency to a material which you then can apply to the topo?
    Jonas
    Quote Originally Posted by m20roxxers View Post
    Are you saying I should model the grade as a sloping warped floor and apply transparency to that? I have not tried that, seems like a good idea if in fact toposurfaces can not be rendered with transparency. However, I was hoping to get a grassy textured topo surface
    Quote Originally Posted by JH75 View Post
    Jonas
    I have tried adding transparency to the material element property topo surface, trying both image files and single colors. I can get the 3D views transparent, but not a rendered image. I have tried checking transparent and even halftone for the visibility of the topography category in the VG dialog box.
    thanks,
    jeff
    Active Member Peter Davies's Avatar
    2005-08
    Christchurch, New Zealand
    64
    Unhappy Re: Rendering with a Transparent Image Toposurface?
    Quote Originally Posted by jeffsmith7 View Post
    thanks,
    jeff
    Hi Jeff, as far as I know rendering ignores transparency.
    2008-07
    349
    For the site material it is actually an options under Render Apperance where you can set Transperancy - but changing it doesn't seem to affect the rendering ie the site is not having any transperancy and yes I did check that the material was applied
    Jonas
    2005-12
    Hi,
    of course. Simply apply e.g. a glass material with low reflections to your topo surface and render.
    Regards, Carlos
    Quote Originally Posted by castaneda111 View Post
    Hi,
    Regards, Carlos
    Thanks Carlos, I will go with that unless I figure out another way. It seems odd that the Material dialogue box for the toposurface has transparency settings for most materials in the Rendering Appearance tab, yet they don't work...oh well..
    Jeff
  1. Rendering Issues - Materials don't show up as Transparent
    By emcculloch in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-10-19, 03:21 PM
  2. How to make an inserted Raster Image's background transparent ?
    By winston_smith_will_win in forum AutoCAD General
    Last Post: 2009-09-17, 11:54 PM
  3. Site toposurface not rendering
    By mikemck in forum Revit - Rendering
    Last Post: 2005-05-16, 05:55 PM
  4. Overlaying a transparent image
    By Kirk Bricker in forum Revit Architecture - General
    Last Post: 2005-05-05, 07:41 PM
  5. wmf to gif image with transparent background
    By wpeacock in forum VBA/COM Interop
    Last Post: 2004-10-13, 01:08 PM
