Thread: Change angles of Mtext to new Angles
    2007-07
    85
    Default Change angles of Mtext to new Angles
    I have an isometric drawing with lengths and diameters along it's lines.
    All mtext put at 150 angles (which is upside down) should become 330.
    All mtext put at 270 angles (which is the wrong way round) should become 90.
    I have put together some code, but it seems there is no way of getting the rotation of an object without showing the program 2 points.Is there any way to get the angle straight away? I don't think .getangle or .anglefromXaxis will get me anywhere.
    (entget (car (entsel))) gives me no clue as to where to get the angles from.
    Perhaps the radians value is stored somewhere so I can pick it up from there?
    This is what I've got so far:
            Dim LongDiamTekst as AcadMtext
            Dim Degrees as Single
            Dim Radians as Single
            Dim Pi As String
            Pi = "3,14159265"
            Degrees = Radians * 57.29578
            Radians = ?????
            If Degrees > 145 Then
            If Degrees < 155 Then
                LongDiamTekst.Rotation = (Pi / 180# * 330#)
            End If
            End If
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,777
    Default Re: Change angles of Mtext to new Angles
    The Rotation property stores the angle. First set Degrees to the extisting Rotation prop. All angles are stored in radians.
    C:> ED WORKING....
    2007-07
    85
    Thank you. I worked it out with your advice, and am very happy now.
  1. Angles
    By Jrobker in forum Revit MEP - General
    Last Post: 2009-09-24, 06:37 PM
  2. Angles
    By dsw98 in forum Revit Architecture - General
    Last Post: 2005-09-12, 06:32 PM
  3. Dim's on Angles
    By pwmsmith in forum Revit Architecture - General
    Last Post: 2004-11-03, 07:19 PM
  4. how to change camera angles in walkthroughs?
    By scott.68993 in forum Revit - Rendering
    Last Post: 2004-06-22, 06:25 PM
  5. how to change camera angles in walkthroughs?
    By scott.68993 in forum Revit Architecture - General
