Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Convert Survey Figure and Feature Line to 2D Polyline
  1. #11
    Earth
    9,805
    Default Re: Convert Survey Figure and Feature Line to 2D Polyline
    I don't suppose you have an update that will process multiple feature lines at once?
    If not, do you mind if I make the edits and post the revised code here?
    R.K. McSwain | CAD Panacea |
  2. #12
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    I figured someone would ask. I developed the _ConvertFigureToPolyline function to accept a single figure line type object. The ssget found in the figure2poly would need to be modified along with the necessary loop to accept multiple feature lines.
    I will not be posting my edit. You are free to do so here, though.
  3. #13
    Earth
    9,805
    Done.... with the disclaimer that this was a quick and dirty edit. It served my purpose this morning.
    Thanks!!
    (defun _ConvertFigureToPolyline	(oFigure      /
    				 arr2DPoints  arrSpace	   fr
    				 i	      lst2dPoints  lstBulge
    				 lstVariables objPolyline  ss
    				 x	 y	      z
      ;; Begin Main Routine
      (setq	i  -1
    	x  0
    	fr (_safelist (vlax-invoke-method oFigure 'GetPoints 1))
      (repeat (/ (length fr) 3)
        (setq y (1+ x)
    	  z (1+ y)
    	  lst2DPoints
    	   (append lst2DPoints (list (nth x fr) (nth y fr)))
    	  lstBulge
    	   (append lstBulge
    		   (list
    		     (vlax-invoke-method
    		       oFigure
    		       'GetBulgeAtPoint
    		       (vlax-3d-point
    			 (list (nth x fr) (nth y fr) (nth z fr))
    	  x (+ x 3)
      (setq	arrSpace
    	 (vlax-make-safearray
    	   vlax-vbdouble
    	   (cons 0 (- (length lst2DPoints) 1))
      (setq arr2DPoints (vlax-safearray-fill arrSpace lst2DPoints))
      (vlax-make-variant arr2DPoints)
      (_SetSysVar "clayer" (vla-get-layer oFigure))
      ;(if (not (tblsearch "LAYER" strBreaklineLayer))
      ;  (_AddLayer strBreaklineLayer)
      ;(vla-put-layer oFigure strBreaklineLayer)
      (setq	objPolyline
    	 (vlax-invoke-method
    	   (_Space)
    	   'AddLightWeightPolyline
    	   arr2DPoints
      (foreach n lstBulge
        (vla-setbulge objPolyline (setq i (1+ i)) n)
    (defun c:figure2poly (/		   _AddLayer	_Space
    		      _SetSysVar   *Error*	strBreakline
    		      _safelist	   _variantvalue
    		      ss	   oFigure
      (vla-startundomark
        (vla-get-activedocument (vlax-get-acad-object))
      ;; Initiliaze user defined variables
      (setq strBreaklineLayer "breakline")
      ;; Defun subroutines
      ;;_ Returns the active space object
      (defun _Space	(/ *DOC* space)
        (setq *DOC* (vla-get-activedocument (vlax-get-acad-object)))
        (setq space	(if (= 1 (vla-get-activespace *DOC*))
    		  (vla-get-modelspace *DOC*) ;_ Model Space
    		  (if (= (vla-get-mspace *DOC*) :vlax-true)
    		    (vla-get-modelspace *DOC*) ;_ Model Space through Viewport
    		    (vla-get-paperspace *DOC*) ;_ Paper Space
      (defun *error* (strMessage /)
        (if	(or
    	  (= strMessage "Function cancelled") ; If user cancelled
    	  (= strMessage "quit / exit abort") ; If user aborted
    	  (null strMessage)		; End quietly
    	)				; End or sequence
          (princ)				; Exit quietly
          (princ (strcat "\nError: " strMessage)) ; Report Error
        (if	lstVariables
          (mapcar '(lambda (x) (setvar (car x) (cdr x))) lstVariables)
        (vla-endundomark
        (princ)
      ;;_ Adjust system variable and save original to list
      (defun _SetSysVar (name value /)
        (if	lstVariables
          (if (null (assoc name lstVariables))
    	(setq lstVariables
    	       (append lstVariables
    		       (list (cons name (getvar name)))
          (setq lstVariables (list (cons name (getvar name))))
        (setvar name value)
     ;_ Add a new layer to the layers collection
     ;_ Syntax (AddLayer "layername")
     ;_ Function returns T if successful nil if not
      (defun _AddLayer (strLayerName / objLayer)
        (if	(and (= (type strLayerName) 'STR)
    	     (not (tblsearch "LAYER" strLayerName))
          (progn
    	(setq
    	  objLayer (vla-add
    		     (vla-get-layers
    		     strLayerName
    	(vlax-release-object objLayer)
    	t
     ;_ Convert Safearray to list
      (defun _safelist (value)
        (if	(= (type value) 'VARIANT)
          (setq value (_variantvalue value))
        (setq value (vl-catch-all-apply 'vlax-safearray->list (list value)))
        (if	(vl-catch-all-error-p value)
          nil
          value
     ;_ Get value of variant
      (defun _variantvalue (value)
        (setq value (vl-catch-all-apply 'vlax-variant-value (list value)))
          nil
          value
      (princ
        "\rConvert a feature line or survey figure to polyline... "
      (setq myss (ssget '((0 . "AECC_SVFIGURE,AECC_FEATURE_LINE"))) i 0)
      (repeat (sslength myss)
        (setq oFigure (vlax-ename->vla-object (ssname myss i)))
        (_ConvertFigureToPolyline oFigure)
        (setq i (1+ i))
    ;;;  (if (setq ss (ssget ":S:E" '((0 . "AECC_SVFIGURE,AECC_FEATURE_LINE"))))
    ;;;    (progn
    ;;;      (setq oFigure
    ;;;	     (vlax-ename->vla-object (ssname ss 0))
    ;;;      (_ConvertFigureToPolyline oFigure)
      (*error* nil)
  4. #14
    2006-11
    7
    Thanks for this. I found a couple of issues, the current layer wasn't reverting back and I wanted linetype generation turned on for proper patterning.
    I moved the main subroutine inside and moved lstVariables and cleaned up a little (deleted unused code and variables)
    (defun c:figure2poly ( / _ConvertFigureToPolyline _Space _SetSysVar *Error* _safelist _variantvalue ss oFigure lstVariables )
      (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
      (setq lstVariables nil)
      ;; defun subroutines
      ;; main routine
      (defun _ConvertFigureToPolyline ( oFigure / arr2DPoints arrSpace fr i lst2dPoints lstBulge objPolyline ss x y z )
        (setq i -1 x 0 fr (_safelist (vlax-invoke-method oFigure 'GetPoints 1)))
          (setq y (1+ x) z (1+ y) lst2DPoints (append lst2DPoints (list (nth x fr) (nth y fr))))
          (setq lstBulge (append lstBulge (list (vlax-invoke-method oFigure 'GetBulgeAtPoint (vlax-3d-point (list (nth x fr) (nth y fr) (nth z fr)))))))
          (setq x (+ x 3)))
        (setq arrSpace (vlax-make-safearray vlax-vbdouble (cons 0 (- (length lst2DPoints) 1))))
        (setq objPolyline (vlax-invoke-method (_Space) 'AddLightWeightPolyline arr2DPoints))
        (foreach n lstBulge
        (vlax-put-property objPolyline 'LinetypeGeneration :vlax-true)
      ;; returns the active space object
      (defun _Space ( / *DOC* space )
                        (vla-get-paperspace *DOC*)))))           ;_ Paper Space
      ;; error routine - restores system variables
      (defun *error* ( strMessage / )
        (if (or (= strMessage "Function cancelled") ; If user cancelled
                (null strMessage))                  ; End quietly
          (princ (strcat "\nError: " strMessage)))  ; Report Error
        (if lstVariables (mapcar '(lambda (x) (setvar (car x) (cdr x))) lstVariables))
        (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
        (princ))
      (defun _SetSysVar ( name value / )
        (if lstVariables
            (setq lstVariables (append lstVariables (list (cons name (getvar name))))))
          (setq lstVariables (list (cons name (getvar name)))))
        (setvar name value))
      (defun _safelist ( value )
        (if (= (type value) 'VARIANT) (setq value (_variantvalue value)))
        (if (vl-catch-all-error-p value) nil value))
      (defun _variantvalue ( value )
      (princ "\rConvert feature lines or survey figures to polylines... ")
        (setq i (1+ i)))
      (*error* nil)
      (princ))
    (princ)
  5. #15
    2004-08
    Tennessee
    8
    Can you edit the multiple selection figure2poly routine to move the featureline to the breakline layer like the single object figure2poly routine does?
    Thanks ahead of time,
    Mike McCulley, RLS
  6. #16
    2017-12
    I have successfully made the figure@poly command. I need help making the command convert multiple feature lines at the same time.
  7. #17
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by CStark86 View Post
    Please see one of the two responses to my code making it work on multiple feature lines.
  8. #18
    2019-03
    4
    First off, great lisp, and then one question, what would be modified if I wanted to simply delete the figure / feature line once the polyline has been created?
  9. #19
    2023-06
    @Opie,
    Your routine to convert a survey figure line to polyline is great. It’s been a long time since I have written a lisp program, about 25+ years ago. The routine you posted only converts one survey figure line at a time. I would like to have the program convert all the survey figures to polylines at one time, so build a selection set, covert a survey figure line to polyline, then delete the survey figure line, repeating until the entire selection set has been processed. I don’t remember how to create a selection set and survey figure lines didn’t exist when I did programming. I’m hoping you, or someone, can help me out with this.
    Thank you,
    Civil 3D 2022, 2022.2.3 Update
  10. #20
    2002-01
    jUSt Here (a lot)
    9,106
    Check some of the edits others provided in this thread to my routine.
  1. Double Click a Line to Convert it to a Polyline
    By zoomharis in forum AutoCAD Tips & Tricks
    Last Post: 2016-05-29, 09:21 PM
  2. Line Work (Survey Figure) Issue
    By dwknutson in forum AutoCAD Civil 3D - General
    Last Post: 2012-11-29, 02:46 PM
  3. Create an Alignment from a Survey Figure Line
    Last Post: 2012-11-13, 03:02 PM
  4. Convert feature line to alignment/profile
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-10-06, 02:10 AM
  5. Convert an ARC to a Line or Polyline
    By nigel.chesworth in forum AutoCAD General
    Last Post: 2006-01-13, 10:02 PM
