Summary: The abiliy to purge annotation scales assigned to objects that are not for the current active annotation scale.
Description: Ability to delete all annotation scales assigned to objects that are not for the current active annotation scale. This can be incorporated as a right-click option or a menu tool or command. Or it could be like a purge tool that shows all the currently assigned scales in a dialog box. Users can then check or uncheck the scales to keep or delete. An additional check box or option would be to add the selected scale(s) to all objects that can be assigned an annotation scale.
How Used: This will result in 'cleaner' nore efficient drawings. It will also help eliminate some of the errors that are introduced when multiple annotation scales are used in a drawing.
Feature Affinity: Modify
Submitted By: Perry Medina on January 29, 2009
