Thread: Sheet Set Manager Plotting
    2008-12
    46
    Default Sheet Set Manager Plotting
    Hello;
    I am just learning how to use the sheet set manager to organize a DD set. I've already created the files and sheets but the layouts are the wrong size with the wrong template and I do not know how to change it. Does anyone know? Thanks so much.
    2006-12
    Big "D"
    3,710
    Default Re: Sheet Set Manager Plotting
    Quote Originally Posted by c.mcmahon View Post
    Hello;
    If you have a template already set up, you can set it so that PN will use it when creating sheets. Go to the project tab in project navigator, then where it says current project, select the little square that has a pencil in it. That will bring up the project properties. Under Basic, you will see a section called Templates. That's where you set the path for the sheet template.
    Any sheets that are already set up will need to be deleted and set up again using the new template. Either that, or you may be able to open each sheet and manually detach and attach the correct template in the Xref manager.
    Why is it called common sense when it is so rare?
    RevitForum.org
  1. Plotting using Sheet Set Manager
    By woodychang in forum AutoCAD Plotting
    Last Post: 2010-06-08, 02:00 AM
  2. Sheet Set Manager - Multiple Plotting function
    By DeluXe in forum AutoCAD General
    Last Post: 2009-09-10, 11:58 AM
  3. Sheet Set Manager / Plotting to PDF
    By bcole.200021 in forum AutoCAD Sheet Set Manager
    Last Post: 2009-03-04, 04:33 PM
  4. Multi sheet plotting in Sheet set manager
    By tim.ashton in forum AutoCAD Plotting
    Last Post: 2007-01-27, 01:00 PM
  5. Problems plotting from sheet set manager
    By jwilliams.67235 in forum AutoCAD Sheet Set Manager
    Last Post: 2005-07-05, 09:12 PM
