Thread: Slab edge moves with wall
    2008-02
    30
    Default Slab edge moves with wall
    We have found that when a slab is drawn with an edge coinciding with an existing wall the slab edge locks to the wall and therefore moves with the wall when the wall is moved. There is apparantely no way to disconect the wall from the slab edge with the only work around being to cut the wall and paste the wall back in the same location, however this is a problem when the wall has tags associated with it as all these tags will disappear when the wall is cut and pasted. has anyone else encountered this problem and is there a solution to it?
    2005-10
    321
    Default Re: Slab edge moves with wall
    This is a fatal flaw in the software.
    The best solution/workaround is to group your slabs.
    I will see if I can locate my post from a while back.
    http://forums.augi.com/showthread.php?t=89116
    The only other post I saw mention this:
    http://forums.augi.com/showthread.ph...ll+interaction
    2008-10
    Virginia
    55
    When I have this problem I select the wall and click top/base: detach. Then another button appears labeled "detach all". After clicking that the wall is detached from everything. I apologize if I am not understanding your problem correctly.
  1. 2011: Multi-story exterior wall, trimming framing at slab edge
    By nrollins in forum Revit Architecture - General
    Last Post: 2011-08-15, 09:21 PM
  2. Why does this slab edge offset prevent it from joining to a floor slab?
    Last Post: 2010-10-25, 09:49 PM
  3. Slab edge not at wall moves on wall move.
    By allan.wise in forum Revit Structure - General
    Last Post: 2008-12-02, 10:59 PM
  4. Slab Edge Profile not loading under Floor-Slab Edge
    By John Anderson in forum Revit Architecture - General
    Last Post: 2008-06-16, 05:44 PM
  5. Floor Slab Edge host sweep type on a sloped slab
    By gravelin in forum Revit Architecture - General
    Last Post: 2005-02-17, 06:47 AM
