I created a column from a HSS8x2x3/16 material that then bent 90 degrees to form the shade structure beam (mitered 45 degrees at joint).
Here's the weird part. In order to have model look correct I used cut geometry for both the column and the beam along a 45 degree reference plane I created. Prior to doing this the beam in plan view looked fine in course mode (thick line like it should). Once I cut it along the ref. plane, the line representing the beam disappeared. I could still pick it but it would not show up in the plan view.
Is this a bug or am I missing something here.
Please see attached image.
Thank you.
