Thread: Express Tools command PLJOIN in AutoCAD 2005
    2004-02
    54
    Default Express Tools command PLJOIN in AutoCAD 2005
    One of my favourite commands in ACAD 2002 was the pljoin command in the express tools. However, I can't seem to find it in the ACAD 2005 express tools. I can see a lisp file in the express directory called "pljoinsup.lsp" but there is no "pljoin.lsp". Is there a reason it was dropped from the express tools in 2005? And can I get it back?
    Thanks.
    2001-10
    Arizona
    2,337
    Default Re: Express Tools command PLJOIN in AutoCAD 2005
    In the new version try PEDIT, with multiple and join options
    for fuzz distance.
    Command: pedit
    Select polyline or [Multiple]: m
    Select objects: Specify opposite corner: 2 found
    Select objects:
    Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j
    Join Type = Extend
    Enter fuzz distance or [Jointype] <0.0000>:
    0 segments added to polyline
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2004-02
    54
    Thanks Michael,
    That does take care of the fuzz distance and gives me the multiple option, but I still will miss the convenience of doing the join in one step rather than two.
    2001-03
    13,499
    Hi
    Check out the following post within the Autodesk Discussion Groups -
    No "PLJOIN" tool installed with Expresstools on ADT2004
    Have a good one, Mike
    2004-02
    54
    Thanks Mike, This sorted the problem out for me. I appreciate the info.
  1. Install Express Tools with AutoCAD 2005
    By CadDog in forum AutoCAD General
    Last Post: 2006-03-22, 07:45 PM
  2. Replies: 8
    Last Post: 2006-02-23, 09:43 PM
  3. Express Tools command PLJOIN gone in AutoCAD 2006?
    By akall in forum AutoCAD General
    Last Post: 2005-11-10, 08:04 PM
  4. Installing Express Tools in AutoCAD 2005
    Last Post: 2005-02-03, 03:37 PM
  5. Reinstall Express Tools in AutoCAD 2005
    By pmartinez in forum AutoCAD General
    Last Post: 2004-11-01, 08:11 PM
