Results 1 to 10 of 18
Thread: Family Type Parameter - Sloping Column - Sweep Profile
    2008-04
    270
    Exclamation Family Type Parameter - Sloping Column - Sweep Profile
    Hi everyone.
    We have all used sloping columns from time to time, most likely an in-place family, or a beam alligned to a reference plane.
    I am trying to create a sloping column family with the various column sizes "built in"
    I started out by using the Structural column template, then used a solid sweep locked to a reference line. I loaded in a U.B profile for the sweep. That was the easy part.
    After reading "Mastering Revit Structure" it appears a user can add a "Family Type Parameter" to the family that is set to "grab from the profiles category" to enable a user to switch the profile whilst in the project environment. However, the book doesn't go into this detail.
    I have loaded the profiles into the family, and can create a "profile family type parameter," the problem is linking the two together.... I can change the column profile within the family editor but not within the project environment.
    Can anybody help??
    I know the Authors of the book Mastering Revit Structure are active users of the AUGI forums - Thomas S. Weir, Jamie D. Richardson, Eric Wing and David J. Harrington so maybe one of you guys could help??
    Thanks in advance.
    Glenn
    2008-02
    Leeds, UK
    95
    Default Re: Family Type Parameter - Sloping Column - Sweep Profile
    Glenn,
    The new version will have slanted columns. You can check it out here. JP sends his regards from sunny Leeds
    Balazs
    2008-04
    270
    Who would of thought. Of all the people in the world to reply to my post, my old mate JP replies from back in Leeds.....
    If they have sloping columns in the new version then happy days, providing you can select the column size from the catalogue file.
    2007-03
    Melbourne, Australia
    278
    The type catalog just needs to have the exact same name as the Family it is referencing to
    You also need to be very particular with the spelling and CAPS within the type catalog, so if you have just copied and already existing catalog you can just save as the new family name in the same directory and it will pick up the type catalog for you
    Hope that helps
    2008-04
    270
    It isn't a type catelogue issue, there is an alternative way to do it, and that is what I am trying to find out.
    Thanks.
    2008-06
    Sunshine Coast, QLD
    40
    It doesn't seem possible to link a sweeps profile to a parameter. You can link the offset, angle and whether it's flipped and others, but not the profile itself. Normally you would select the sweep in the family, go to its Element Properties and select the grey box on the right of the parameter you wished to link to your created one. There's no box next to Profile.
    The out-of-the-box steel beams have two profiles loaded in and switched by visibility states (for medium and fine details levels). If it was possible to change profiles of a sweep using a parameter, you'd think they'd have used that instead of loading/constraining two separate sweeps (and then the 3D view saved with the beam wouldn't look arse because it had two similar sweeps in the same spot).
    2008-04
    270
    Thanks, I have been in direct contact with Eric Wing (one of the Authors of Mastering Revit Structure 2009, and also a big player in AUGI.) He assures me it can be done (as stated in the book) but I am yet to get a further response.
    By all accounts RST 2010 will have sloping columns so this is a problem that will soon become redundant.
    Saying that I am still keen to find out how to do this, so if anyone knows how.....
    Regards
    Glenn
    2006-05
    836
    Sweep profiles can easily be linked to parameters.
    Obviously you need to have the profile with parameters in the first place.
    The only difference i one loaded into the sweep, you need to associate the parameters by right clicking on the profile family in the project browers and going to properties.
    From here you can click on the associate parameters button to link them across.
    Hope that helps
    2008-04
    270
    Thanks, I will give that a try!
    100 Club jrichardson's Avatar
    2005-07
    St. Paul/Minneapolis, MN
    143
    Glenn,
    I feel bad about this since I wrote that sentence that you are reading. I have been trying everything to make it work and it just does not want to.I can't find the needle in the hay stack that will make it work. It looks like it works with other nested families but not profiles. I must have got carried away with my words. I will be sending it into support to see what they say.
    As already said above, what you can do is, create the same parameters that are in the profile in your sloped family. Then select the profile and map the parameters back to the ones in your family. This should allow you to at least swap out sizes from the same profile. You could introduce a type catalog to populate the sizes.
    I know this is not what you were ultimately looking for, but at least you have an answer from the person who said it.
    I will keep digging. I will have to go back to a previous version and give it a shot.
    jamie
  1. Sweep column family component in a project file
    By vtandre433916 in forum Revit Architecture - Families
    Last Post: 2014-06-17, 07:08 PM
  2. Replies: 12
    Last Post: 2013-10-26, 03:33 PM
  3. Profile Type driven by parameter?
    By barrie.sharp in forum Revit Architecture - Families
    Last Post: 2009-07-08, 03:56 PM
  4. Can't set a sweep profile to a Family Type parameter?
    By patricks in forum Revit Architecture - Families
    Last Post: 2009-03-19, 11:14 AM
