Results 1 to 6 of 6
Thread: helical form
    2009-02
    11
    Default helical form
    hey can any one tell me how to create a helical object (column or tube) in revit
    2006-12
    Maine
    57
    Default Re: helical form
    Are you looking for something like a twisted hexagon, or a spring?
    If you want a twisted hexagon, you can use the Solid Form >> Solid Blend tool. It allows you to create a hexagon shape for the bottom and another one for the top. Then just rotate the top hexagon and play with the Vertex connectors to get the desired result.
    If you want a spring, then I am not sure.
    2009-02
    11
    i want a similar shape like spring can u tell me..
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Here is a spring like shape I did in Revit. I used the swept blend tool. First I establish a path that is almost a circle (Revit will not allow a completly circle path for the swept blend.) Then I drew the 2 profiles for the start and end of the blend. The second profile I moved up a bit before finishing the blend. Once finished it will sweep in the cirrcular path but because the profiles are offset it will sweep in a helical shape. ONce I had one shape I then made an array of a few of them to create the "spring"
    Try using stair railings to make helical forms.
    Attached is an example of a helical ramp, the walls and curb are just a custom profile for a handrail.
    2009-02
    11
    Smile Re: helical form
    thnks for helpin me
  1. Helical Piers
    By hhall in forum Revit Structure - Families
    Last Post: 2013-05-30, 01:54 AM
  2. Helical Pile Family
    By hhall in forum Revit Structure - General
    Last Post: 2009-06-10, 07:18 PM
  3. Helical Geometry for Curving Staircases
    By 3d generator in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-05-22, 03:39 PM
  4. Cut Geometry, Solid form, Void form
    By mmolina in forum Revit Architecture - General
    Last Post: 2005-05-11, 09:33 PM
  5. helical gear trouble
    By info.78032 in forum MDT - General
    Last Post: 2004-11-15, 05:21 AM
