Summary: Whe mirroring a component be able to set the constraints as it is done
Description: A Reflection or mirror Constraint would be very helpful when using the mirror components tool. You can only mirror in one plane, so it should be easy to automatically copy the constraints in the other directions and have a new constraint. How often have to used the mirror tool and forogt to constrain the new component?
How Used: The new constraint would have to consist of two parts. One part is driven and between the original part and the mirror plane. The second part is of the constraint is between the mirror plane and the new components. if the original compoent were to be move the mirrored component would also move.
Feature Affinity: Assemblies
Submitted By: Duncan Anderson on January 9, 2009
