Summary: Layers to assign colors to assembly sketch lines
Description: Having Layers for complex Skeletal sketching would make life a lot easier when you have more than one sub-asm in a skeletal sketch.
How Used: I usually have only one sub-asm in a skeletal sketch, but on occassions there are times when one sub-asm references another sub-asm and vice-versa. In which case is is necessary to project the geometry.. This is easy when you're projecting geometry from Sketch1 to Sketch2, but it doesn't work the other way around.
Feature Affinity: Sketching
Submitted By: Duncan Anderson on January 23, 2009
