Thread: opacity texture
    2008-05
    66
    Default opacity texture
    anywhere can i find the opacity texture?
    for mesh flooring
    thanks
    sam
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Default Re: opacity texture
    Quote Originally Posted by sam_ctlim View Post
    for mesh flooring
    thanks
    sam
    Hi..You question is a little vague, but I am assuming you are in full render mode and want this particular texture to be more transparent. You need to go to Global Options>Tools>Presenter and set the profile to advanced. You will then get additional options when you are in the Presenter module to change the material's opacity. It will depend on how the material is made. You might want to start with a glass material and add the mesh over the top.
    Best regards,
  1. Material Opacity
    By MikeRobinson in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-03-23, 01:40 PM
  2. Problem with Opacity File
    By essdubbya in forum Revit - Rendering
    Last Post: 2006-01-19, 07:23 AM
  3. Problem with Opacity File
    By essdubbya in forum Revit Architecture - General
  4. Opacity folder crashes Revit - why?
    Last Post: 2005-12-08, 07:00 AM
  5. DWF Text Opacity
    By Batman in forum Revit Architecture - General
    Last Post: 2005-07-05, 05:12 AM
