Thread: 3D DWF, can you test this for me?
    2008-06
    Adelaide, South Australia
    279
    Default 3D DWF, can you test this for me?
    Can somebody please do me a favour and insert this light fitting into a new project, export to a 3D DWF and see if the light source is solid?
    I'm still having the problem of the light source showing as solid in all my 3D DWFs on any fitting that wasn't made by Autodesk. This fitting is one I haven't made, it was downloaded from VISA lighting. If you don't see the light source then it is the templates I'm using.
    Still see the light source on this fitting by the way, and any of mine, but not default fittings.
    I could stop if I wanted to Norton_cad's Avatar
    2007-05
    Bardwell Valley, Sydney, Australia
    434
    Default Re: 3D DWF, can you test this for me?
    Hi,
    I inserted all three lights, via drag n drop from the project browser.
    The first two were host based on a gridded ceiling, the last one (LampingDes(120V) was hosted to a floors (?).
    After export to 3D DWF and putting a cross section it looks okay. I've attached it for your comparison.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2008-06
    279
    Cheers, FYI we just figured it out!
    Our IT department decided we didn't need the IES files that all our light sources link to every time we edit them and so they got rid of them. The seem to enjoy deleting things from our machines because they assume we don't need them (render library, windows character map, etc).
    Since it can't find the IES file it inserts some default geometry and then when you load it back into the project it messes up.
    2007-05
    434
    Flipping IT/CAD managment strikes again! I can empathise, as per my previous thread.
    http://forums.augi.com/showthread.php?t=76139
    Regards,
    Mark Norton,
  1. test
    By sandrews.253556 in forum New Forum Users (Non technical)
    Last Post: 2011-01-13, 08:26 PM
  2. Test
    By Dinochrome in forum New Forum Users (Non technical)
    Last Post: 2010-11-19, 02:15 AM
  3. Cad Test
    By nealblanche in forum ACA General
    Last Post: 2006-10-24, 11:03 PM
