Thread: Fatal Error: Unhandled Access Violation Reading 0x0000 Exception at 60c068h
    2009-02
    Exclamation Fatal Error: Unhandled Access Violation Reading 0x0000 Exception at 60c068h
    Hi guys,
    I having trouble using AUTOCAD 2009. It all installs perfectly but when trying to use it this error comes up:
    I have no clue what to do and need help urgently.
    Thanks
    2015-12
    Chesterfield, MI
    405
    Default Re: Fatal Error: Unhandled Access Violation Reading 0x0000 Exception at 60c068h
    What operating system are you installing it on?
    I don't know if this will help or not but I had the same type of issue with a Vista machine yesterday. It ended up being a permissions issue.
    Even though my network login has full local admin rights AutoCAD would not run until I logged in as the true local admin (not logged into the domain) and uninstalled and reinstalled AutoCAD.
    This was the first time that this happened and I have done the same install on over 50 Vista computers.
    Hope this helps.
    Brett
  1. Replies: 1
    Last Post: 2007-12-20, 01:12 PM
  2. Replies: 5
    Last Post: 2006-05-05, 01:22 PM
  3. Replies: 4
    Last Post: 2006-02-21, 03:02 PM
  4. Replies: 2
    Last Post: 2005-10-24, 05:29 PM
