Thread: VBA userform in excel
    2009-01
    8
    Default VBA userform in excel
    Have completed a code within AutoCAD VBA to export all required info to an excel spreadsheet.
    My next problem is updating the code within excel, I am wanting to do this with simple userforms.
    As all my code is in CAD VBA, is there a way I can show the userforms in excel - not in CAD.
    Alternatively can I produce a new excel code and load that at the end of the CAD code
    Hope i've explained it ok
    2008-06
    52
    Default Re: VBA userform in excel
    I don't know anyway to get your CAD VBA forms to show up in Excel. However you can call Excel Macro's from an AutoCAD Macro.
    Example:
    Dim XLApp As Excel.Application
    Set XLApp = GetObject(, "Excel.Application")
    XLApp.Application.Run "Book1!Macro1"
    Turlock, CA
    6,420
    It depends on what you want to do with the form in xl. However, you can design a form in xl and call it from acad. A form designed in acad can define and reference xl objects as well.
    C:> ED WORKING....
    LinkedIn
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Just a thought.... I haven't tried this myself but.........
    Tile the Acad and Excel windows on your screen so that popup windows in both will be visible.
  1. Parameters from Userform
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2010-04-26, 06:25 PM
  2. Unload a userform
    By mikeosborne in forum VBA/COM Interop
    Last Post: 2009-09-28, 08:35 PM
  3. All I want is a Userform to show..
    By Coolmo in forum Dot Net API
    Last Post: 2009-07-23, 02:03 PM
  4. Reference Excel Spread sheet in a userform combobox
    Last Post: 2009-04-30, 06:22 PM
  5. Userform limit
    By Coolmo in forum VBA/COM Interop
    Last Post: 2007-06-22, 06:29 PM
