Hi, Does anybody have a Lisp Routine that can convert XY Coordinate (0,0,0) to Surveyor Units (N 0d00'00" w)?
When I ID a point I need it in Surveyor Units not Decimal.
Thanks
Thanks
I'm not following what you're looking for here -- The example you gave is an angular value, and there's no possible way to get from an ID command on a point (X and Y coordinates) to a bearing or angle.
Now if you want to get Northings and Easting coordinate values, that's different. Presuming North is up on your drawing, then the Y value is N and the X value is E. in other words, to convert
Command: id
Specify point: X = 33.4837 Y = 17.7333 Z = 0.0000
to NE format, it's
N 17.7333
E 33.4837
Officially Awesome
It looks like you are trying to convert to longitude and latitude. AutoCAD cannot do that, but I believe AutoCAD Map 3D can.
So, Autocad Map 3D can give you coordinates in Long & Lat as well as Northing & Easting, Right?
I searched all the features for it in the Autodesk website but did not find any to indicate that. It only states that it is used for "coordinate geometry". But what coordinate?Can any body who uses this program please reply and tell me that it does or not give Long & Lat?
Thanks
I had a go with standard ACAD. Attached is a file where the units are set to degrees & minutes, and a node is noted with a multi leader, and feild text.
Is this sort of what your looking for?
Ohm's Law - Electricity follows the path of least resistance.
Regards,
Mark Norton,
