I am using [AutoCAD] MEP 2009, and recently the "Quick View Layout" tabs are not refreshing with the correct view. They are all staying the same. How do I refresh each layout to show the correct view?
I think you have to type: UPDATETHUMBSNOW
there might be one where it will do all of them, but if you type "update" then use TAB to cycle through the common commands that begin with update to find your particular need.
That might solve your problem. Let me know if that works..
jason
Thanks Jason for your help....but unfortunately that command does not work "Updatethumbsnow"....I tried it and nothing happens.
