Thread: Stairs-Hidden riser and Treads
    2003-12
    Jacksonville, Fl
    273
    Default Stairs-Hidden riser and Treads
    I am looking for a solution to indicate stair riser and treads as dashed when hidden by the stringer in a section view.
    Pat Wm Smith
    2006-01
    4,516
    Default Re: Stairs-Hidden riser and Treads
    You can set the view to wireframe, then use the line tool on them to make them dashed, then set the view back to hidden line...
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
    2004-06
    Memphis TN area
    6,701
    If you make the stringer using a railing profile (like what many of us do for steel C-channel stringers), then you can simply use the Show Hidden Lines tool, up there next to the Linework tool. Your first pick will be your stringer, then the 2nd pick will be the stairs, and voila! hidden stair lines. The line type/style/pattern of the hidden lines for all objects using the Show Hidden Lines tool is controlled by the Hidden Lines subcategory for each element type category in Object Styles or V/G overrides.
    AERC, PLLC
    Hernando, Mississippi
  1. Stair treads continuing past riser
    By mjohns18 in forum Revit Architecture - General
    Last Post: 2008-10-23, 05:53 PM
  2. DB Stairs - Make it so the treads are variable
    By Rico in forum Dynamic Blocks - Technical
    Last Post: 2006-05-24, 03:38 PM
  3. very unequal riser stairs.
    By mike_sheehan in forum ACA General
    Last Post: 2005-01-11, 10:53 PM
