Thread: need help with visibility issue
    2009-02
    58
    Default need help with visibility issue
    I created a hatch region (diagonal up) for my 2x4 light fixture (for an emergency fixture) and it looks right in the family view, but not on my floor plan view after I've imported to the project. The hatch region seem to be larger than 1/8" spacing and so it doesn't show up right. Is there a way to change the size in the floor plan?
    2009-02
    Houston
    686
    Default Re: need help with visibility issue
    Remember that the 1/8" is not the "real" spacing. The 1/8" is the spacing of the hatch when you print. On screen it may look like it is several inches apart. Shoot it to the printer and then scale it off the print. It should come out right.
  1. Visibility Issue
    By wags5116 in forum Revit MEP - General
    Last Post: 2011-08-09, 06:04 PM
  2. CAD Elements visibility issue
    By Tyveka in forum Revit Architecture - General
    Last Post: 2007-08-16, 04:45 PM
  3. Joist Visibility Issue
    By david.kingham in forum Revit Architecture - General
    Last Post: 2005-08-11, 02:18 PM
  4. Visibility issue
    By Wagurto in forum Revit Architecture - General
    Last Post: 2005-08-04, 06:06 PM
  5. Visibility Issue
    By Carl in forum Revit Architecture - General
    Last Post: 2003-08-19, 04:44 PM
