View Poll Results: Allow Specification of Dimension Text Layer, Not Just Color, to Support STB
Voters
2. You may not vote on this poll
  • Yes, I definitely need this.
    1 50.00%
  • This would be useful.
    1 50.00%
  • Nice idea, but I would not use it.
    0 0%
  • No, this is not needed, please work on another feature.
    0 0%
  • This can already be done.
    0 0%
Results 1 to 1 of 1
Thread: Dim Text on Specific Layer instead of having Specific Color
    2004-12
    Athens Greece
    41
    Cool Dim Text on Specific Layer instead of having Specific Color
    If you use STB instead of CTB, then it makes sense that you would want to have the text of the Dimensions on a specific Layer so that you can assign a different PLOT STYLE to the texts of the Dimension rather than having them in a different color which you cannot control by a STB.
    In this way we can have the dimension lines by a thiner plot-style and the dimension texts by a slightly thicker plot-style so that reading is easier.
    Please note that if using CTB one can assign a different color to the dimension texts and therefore achieve the same result easily. The same easy approach is not applicable in case of having STB for ploting.
    Another manner to approach this matter is through the Object Display. For the time being and as far as I can understand, there is no way to have the text of a dimention printed differently than the dimension lines IF using a STB for ploting.
  1. Which variables are Drawing Specific and Which are Session Specific?
    By stusic in forum CAD Management - General
    Last Post: 2013-09-10, 01:28 PM
  2. Ability for dimension and multileader text to be on a specific layer
    Last Post: 2012-02-03, 08:56 PM
  3. Ability for dimension and multileader text to be on a specific layer
    Last Post: 2012-01-19, 06:06 PM
  4. Replies: 0
    Last Post: 2008-03-17, 02:07 AM
  5. Replies: 9
    Last Post: 2005-11-02, 01:09 PM
