Not sure if anyone else has encountered this problem, but when i create a concrete slab w/ rigid insulation below, and then attach a slab edge to it, the slab edge joins to the insulation, and section cuts show the rigid insulation going straight through the slab edge. i can get around this by either creating a separate floor that is the insulation, and then editting the edge position, or by cutting back the slab w/ insulation, and placing a second floor slab around the edge of the building that i then attach my thickened edge to. both workarounds are not ideal, & i would like to be able to model the insulation, rather than having to detail it every time i make a section cut.
Secondly, there is no way to create a profile to represent rigid insulation below the thickened slab edge within the profile itself that i have found.
Any suggestions??
