Results 1 to 10 of 10
Thread: Array center, but hold the ends
    All AUGI, all the time SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    500
    Default Array center, but hold the ends
    I am working on a DB for bridge box beams. I want to leave the ends but array the center beam. What actions or parameters should be used? I have attached the block to see how far I have gotten.
    2007-09
    Macclesfield Cheshire, England.
    46
    Default Re: Array center, but hold the ends
    Hi,
    Sorry, but I don't quite understand what you mean by "... leave the ends and array the centre beams"
    Maurice.
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    while i'm kind of confused as to the intent as well, i'm wondering if it's similar to the ACT block found HERE?
    S&D DB Sharing Forum
    2004-06
    500
    Quote Originally Posted by Chris.N View Post
    Yes, close. In my DB I have 3 box beams. The ones on the ends are always flush on the outside edge. I want to be able to do a linear array with the middle block and have the end block go along for the ride.
    2001-12
    Rochester, MN
    2,561
    then you have to start with 2 entities. i thought the default vis state in file posted worked like you wished. am i missing something?
    2004-06
    500
    The vis-state BI-36 works except the box beam on the right should always stay on the right of the center box beams as it does the linear array to the right. Right now it is stationary and the box beam that arrays overlaps and then goes past it as you pull it out.
    Sorry I can't explain it better.
    Once I get that vis-state to work, I will carry the same over to the other 7 vis-states.
    2008-12
    175
    Is this what you are after, I set the distance to increment and distance to 3.
    I also tested a move command with another end block with a distance of 3 so that both end blocks are mirror images of each other.
    John
    2004-06
    500
    Quote Originally Posted by jnoon View Post
    John
    That's it! So, if I see it right, you added a move parameter to the right end block and put the array and the move point on top of each other on the lower right corner.
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by SRBalliet View Post
    move ACTION. it was just added to the linear parameter.
    2004-06
    500
    Thank you, Gentlemen.
  1. 2012: Stretching an X While Rotating Items at Ends to Aim Towards the Center
    By nickroz in forum Dynamic Blocks - Technical
    Last Post: 2012-08-28, 06:12 PM
  2. Array from center equally two directions
    By jnoon in forum Dynamic Blocks - Technical
    Last Post: 2009-09-08, 12:12 PM
  3. Joist ends extending to center of wall
    By Patrick.Olstad in forum Revit Structure - General
    Last Post: 2009-06-12, 09:55 PM
  4. Array about center
    By marchitect_nc in forum Dynamic Blocks - Technical
    Last Post: 2009-01-05, 04:59 PM
  5. center an array
    By eglover in forum Revit MEP - Families
    Last Post: 2008-12-11, 07:54 PM
