Thread: Checking a IPJ Back into Vault
    100 Club Commissar Rod's Avatar
    2006-01
    Harrisburg, PA
    137
    Default Checking a IPJ Back into Vault
    has anyone else ran into the problem that after they edit an ipj file and try to check it back into the vault, it says the file cannot participate in check in operation because it is being used by another process? I closed inventor, and Vault, restarted, selected a different inventor project then the one i was trying to check in, restarted, etc, and it still says that. Even if the first thing i do after starting windows is open vault and try to check it in, it says the same thing.
    Does anyone know what might be going on and how i can "jiggle the handle"?
    Thanks!
    Rod
    The opening sequence to "Saving Private Ryan" was based on a game of dodgeball Chuck Norris played in 6th grade
    2008-12
    27
    Default Re: Checking a IPJ Back into Vault
    Checking IPJ's in and out are rather tricky. Are you trying to check it in through Vault or through Inventor? Basically, the process I follow that seems to work is as follows:
    1. Check out the IPJ through Vault/Productstream
    2. Close Vault/Productstream
    3. Open Inventor, edit the IPJ as needed.
    4. Start a new part, switch to the Vault browser.
    5. Check in the IPJ.
    6. Close (don't save) the empty part created in step 4.
    This seems to give me the most success. You cannot have Vault and Inventor open at the same time when working specifically with IPJ files.
    Let me know if this helps!
    2006-01
    Harrisburg, PA
    137
    I was able to check it in with Inventor as you said, thanks!
    2008-12
    27
    Good! Glad that worked!
  1. The ability to create PDF when checking files into Vault
    By ibhutta in forum Vault - Wish List
    Last Post: 2012-07-10, 05:16 AM
  2. checking files out of vault
    By jlucas in forum Vault - General
    Last Post: 2009-05-29, 01:52 PM
  3. Checking into vault
    By jenniferchavez in forum Vault - General
    Last Post: 2008-04-25, 08:50 PM
  4. Replies: 0
    Last Post: 2006-09-12, 08:10 PM
