In general terms, most consulting engineers would show a roof framing plan for example as thick lines. The beams would not be double lines in fine mode, but single thick lines in course mode. At a 1:100 plan you would expect to see something like the attached image (Plan View No Cut) with a space between the beam and column.
The problem comes when you have a sloping column, and on section view you want the column to be shown butted up against the column face with maybe a 10mm gap like the attached image (Section View Cut) it looks good in section but the representation on plan view isn't that great, the beam and column are joined together (refer to attached image Plan View Cut) This isn't how we want our documentation to look.
The best option for plan view is to not cut the beam in section, but then the problem is in section view the column/beam connection looks poor (see attached image Section View No Cut)
My question is, how do we get around this problem? How are other companies using Revit to provide a set of construction documents that look correct in all views?
Is it possible to nest a masking region into the column families with visibility parameters so you can turn on the mask in plan view and turn off the mask in section?
Regards
Glenn Jowett
