Thread: Tandem Wired/Dual Switched Light Fixtures
    100 Club BigBadBIM's Avatar
    2007-07
    Madison, WI
    185
    Default Tandem Wired/Dual Switched Light Fixtures
    Anybody using Revit on projects that have light fixtures that are Tandem Wired/Dual Switched? If so, how are you handling this?
    2005-11
    46
    Default Re: Tandem Wired/Dual Switched Light Fixtures
    I would also like to know the answer to this. My thoughts are add another connector and then wire from connector to the appropiate switch. I did something similiar with fixtures that have an emergency ballast.
    Open for suggestions, please.
    I could stop if I wanted to mhartmann's Avatar
    2005-09
    Saint Louis, MO
    288
    i have done this in classrooms where i have 3 lamp fixtures with a/b switching for 2 lamps and 1 lamp. i showed both switches on the wall, but only tagged one of them as "a,b", and connected all the fixtures to that one, the b switch was just not tagged or even set to b for that matter. my fixture tags then showed "A 14 a,b", being Type, Circuit, Switchleg.
  1. fixtures too light
    By boudreau.245919 in forum Revit MEP - General
    Last Post: 2011-05-03, 01:25 PM
  2. Pendant Light Fixtures and Light Sources
    By heiko.stugg in forum Revit MEP - Families
    Last Post: 2011-01-31, 11:25 AM
  3. light fixtures
    By johnf.77896 in forum Revit Architecture - General
    Last Post: 2008-11-14, 10:38 PM
  4. please help on light fixtures
    By mtogni in forum Revit Architecture - Families
    Last Post: 2006-05-26, 05:05 AM
  5. Light Fixtures
    By dsw98 in forum Revit Architecture - Families
    Last Post: 2006-01-16, 08:54 PM
