Results 1 to 7 of 7
Thread: Converting multiple DWG files to older version
    The Silent Type
    2008-06
    Richmond, VA
    141
    Question Converting multiple DWG files to older version
    I have a few dozen 2007 version DWG files that I need to save as 2004 version DWG files. Is there an easy (automated) method for this, instead of opening/saving one at a time? Thanks in advance.
    Houston
    9,305
    Default Re: Converting multiple DWG files to older version
    Download DWG Trueview - it includes a tool to do batch conversions.
    http://www.autodesk.com/dwgtrueview
    R.K. McSwain | CAD Panacea |
    2005-08
    Albania
    423
    Quote Originally Posted by amsterdamn View Post
    Can you insert your files as blocks then convert them.?
  4. Moderated Post
    The Silent Type
    2008-06
    Richmond, VA
    141
    Thanks, I'll give that a try.
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,312
    If you use eTransmit for your dwgs, there is an option to convert the copies to another version.
    Autodesk Civil3D 2018, Revit 2018
    Gig 'Em, Aggies!
    I could stop if I wanted to Andy.88917's Avatar
    2005-06
    Midland, Texas
    230
    Yup, eTransmit is the way to go!!!
    2015-11
    Jo'burg SA
    4,512
    And then (if using SAVEAS or eTransmit) you could use ScriptPro to run a set of commands in a SCR file on multiple drawings. So the few dozen could become one instruction (without that huge DWGTrueView download).
  1. Converting Multiple Block Files
    By CADdancer in forum AutoCAD General
    Last Post: 2011-09-12, 11:07 PM
  2. Windows XP - Autocad files opening in older version
    By CAD Brad in forum Operating Systems
    Last Post: 2008-08-01, 03:22 PM
  3. Saving as an Older Version
    By Mr Greg in forum Revit Structure - Wish List
    Last Post: 2008-07-01, 12:00 AM
  4. Converting Older Drawings to 2007/08
    By cadmancando in forum AutoCAD General
    Last Post: 2008-01-04, 01:39 PM
  5. Converting older lisp files
    By pstern in forum AutoLISP
    Last Post: 2007-12-10, 02:18 PM
